[O1] Kontrolka ESP i CHECKENGIN plus błędy
  • MarcinRS
    zawsze można dać żółtą folie na lampę
  • boinga
    • 12
    Witam jakieś 2 tygodnie temu pojawiła się w mojej skodzie dwie ikonki jak w temacie plus błędy z waga :
    VAG-COM Version: Release 311.2-N
    1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
    Chassis Type: 1U - Skoda Octavia
    Scan: 01,02,03,08,15,17,19,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 033 BG
    Component: SIMOS33 1.6l 2VG00HS4600
    Coding: 00231
    Shop #: WSC 31480
    TMBHX21U332770083 SKZ7Z0C1889364
    4 Faults Found:
    16935 - Power Steering Pressure Sensor (F88): Implausible Signal
    P0551 - 35-10 - - - Intermittent
    16485 - Mass Air Flow Sensor (G70): Implausible Signal
    P0101 - 35-00 - -
    16556 - Fuel Trim: System Too Rich: Bank 1
    P0172 - 35-10 - - - Intermittent
    P0172 - 35-00 - -
    Readiness: 0000 1001
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 K
    Component: ASR FRONT MK60 0103
    Coding: 0013313
    Shop #: WSC 31480
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 1U1 907 044 A
    Component: CLIMATRONIC C 2.0.0
    Coding: 11010
    Shop #: WSC 31480
    No fault code found.
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 1U0 920 841 B
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 23113
    Shop #: WSC 55026
    1 Fault Found:
    01336 - Data Bus for Comfort System
    80-10 - Single-Wire Operation - Intermittent
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 55026
    1 Fault Found:
    Address 46 -------------------------------------------------------
    Controller: 1C0 959 799 B
    Component: 4P Komfortgerát HLO 0003
    Coding: 00259
    Shop #: WSC 31480
    Address 56 -------------------------------------------------------
    Controller: 1U0 035 156 D
    Component: Radio 0002
    Coding: 00405
    Shop #: WSC 31480
    End -------------------------------------------------------
    mechanik wszystko posprawdzał i rozłożył ręce. przepływomierz był czyszczony. co jeszcze można zrobić?
    • robekcool
      • 2041
      • BJB 1.9 TDI PD 105 KM
      Proponuję zrobić solidniejszą diagnostykę.
      www.k-mot.pl
      Autoholowanie.
      Robert Kulma
        To powoduje brak polaczenia z innymi modulami i dlatego wywala blad ABS.
        Czyli na poczatek trzeba sprawdzic wiazke, a najlepiej sama wtyczke czujnika cisnienia w pompie wspomagania. Jak to jest dobre, to wymienic czujnik.
        Po skasowaniu tych bledow cos szczegolnego dzieje sie z autem ?? Chodzi mi o te silnikowe dotyczace przeplywomierza i ten od od ubogiej mieszanki (sondy, bo to na tej podstawie jest mierzone) jest jego skutkiem
        • boinga
          • 12
          Po skasowaniu błędów z autem nic się nie dzieje takiego ikonki gasną i po paru minutach na włączonym silniku pojawiają się znowu.
          • luckd
            • 316
            Przerabiałem to u siebie, jak błąd się będzie powtarzał to czujnik do wymiany.
            P0101 - 35-00 - -
            Tu trzeba wyczyścić przepływomierz, pozostałe błędy powinny zniknąć.
              Czyszczenie ukladu pomiarowego przeplywomierza to jedno. Czesto nic to nie daje i trzeba przeplywomierzy wymienic.
              Generalnie trzeba zaczac od jego diagnostyki na drodze.
              • crom.de
                • 1545
                Uszkodzony czujnik ciśnienia wspomagania wywala błąd sondy. Nie falują Ci obroty na postoju od czasu do czasu lub przy zatrzymaniu np. na światłach? Mi tylko falowało, wyczyściłem przepustnicę ale nie pomogło. Potem wyskoczył raz na długą chwilę check to podpiąłem do kompa wyszła właśnie sonda plus czujnik. Czujnik ciśnienia wspomagania nie jest może tani, ale raczej będzie konieczne. Ok 200 zł nowy.
                - Superb
                - Panda 1.2
                • boinga
                  • 12
                  Przepływomierz podmienił na nowy z salonu i dalej po przekroczeniu temperatury 60 stopni zaczynał wywalać błędy. Wiec przeinstalował komputer w skodzie i jak narazie nic się nie dzieje. Pojeżdżę i zobaczymy.
                  • fazy2
                    • 168
                    Zamieszczone przez crom.de
                    Mam te same objawy od czasu do czasu jednak VAG pokazuje sporadyczny błąd przepływu mieszanki spalania, a błędu na kontrolkach nie mam, czy też tez mi siada czujnik ciśnienia?
                    Jeżeli mój post coś wniósł, to wyślij ,,pomógł,,
                      fazy2, A masz gaz i jest sporadyczny, to masz odpowiedz Jest zle ustawiony i widac ze czasem jest na pograniczu mieszanki obogiej badz bogatej. Trzeba zlustrowac podczas jazdy korekty krotko i dlugoterminowe.
                      Jak blad zaworka jest, to siedzi blad jego dotyczace na stale.
                      • fazy2
                        • 168
                        Gaz mam, ale problem jest też na etylinie.
                          Bo jest taka zaleznosc, ze jesli sterownik na LPG pojdzie z korekta w jakas strone, to na benzynie nie wroci do normalnosci. Moze byc padnieta lambda, ktora na gazie duzo szybciej ukazuje swoje braki. Korekty trzeba sprawdzic na zywo i potem zastanawiac sie co jest przyczyna.
                          Masz w ogole ESP ??
                          • fazy2
                            • 168
                            Nie stwierdziłem, jedynie ASR i EPC.
                            • crom.de
                              • 1545
                              fazy2, tak jak mówi Maicroft powinien być błąd "błędnej wartości czujnika ciśnienia wspomagania".
                              - Superb
                              - Panda 1.2
                              • boinga
                                • 12
                                A możecie mi powiedzieć gdzie jest ten czujnik ciśnienia wspomagania F88. Bo wczoraj mi zaczęły falować obroty w okolicach 1400-1500 na światłach potem przestały.
                                • fazy2
                                  • 168
                                  Takiego błędu nie mam. Szukam przyczyny moich falujących obrotów, no i dalej jestem w lesie.
                                  • michalrh
                                    • 322
                                    Zamieszczone przez fazy2
                                    posprawdzaj rurę od filtra powietrza do silnika czy gdzieś lewego powietrza nie ciągnie.
                                    • crom.de
                                      • 1545
                                      boinga, czujnik wystaje z pompy w stronę chłodnicy. Falowanie występuje od czasu do czasu. Teraz możesz miesiąc bez problemu jeździć.
                                      - Superb
                                      - Panda 1.2
                                      • fazy2
                                        • 168
                                        Zamieszczone przez michalrh
                                        Rura nie posiada nieszczelności.
                                        • boinga
                                          • 12
                                          Czujnik wymieniony. Koszt czujnika 40 zl plus 45 za litr olej. Godzinka spokojnej pracy i na razie cisza. Oby tak dalej
